Johnny Raptor
LA
Wow, that is really bad, are you close enough to the ocean for the salt air to affect it?
Unfortunately, no. It’s lived its entire life in North La, so we’re 250 miles from the coast. The passenger side is worse than the driver’s. You can feel the rust flexing under the paint.
I’m honestly shocked it’s got rust like that with so little exposure to winter roads. I’d normally question the PO’s truthfulness, but I bought it from my Dad when he decided to buy an R, so I know the complete history of the truck.
I guess it’s not something that has to be fixed immediately, but I hate knowing it’s there.
DEXRAPTURD
Las Vegas
While I was changing a tire on my son’s 2014, I noticed this. Truck is a lifelong southern truck with maybe 3-4 winter trips to the Midwest. Looks like I’ll be dropping by the body shop to see what it’s gonna take to get it fixed.
My 12' did the same thing. I had to paint the entire cab due to the metallic. Cost me close to $2000 to have it done and that included removing windows to do it correctly.
BenBB
Lots of different places
I haven’t seen the video, but basically drain fluid and spray the bajesus out of the driveshaft bolts with some PB Blaster before removing the driveshaft. Before popping it loose tie it up or bungee it to the body above so when it does pop off you can have it out of the way. Might have to pry it off after the bolts are out. I also marked where the driveshaft was to pinion with a paint pen. Used a 12 pt and extension with a wobble adapter and didn’t need to rotate the shaft.
My pinion nut was 1 1/8 I believe and came off with the 1/2 impact. If you don’t have an inch pound TQ wrench, feel the lash/movement on the pinion prior to removing the nut. Then when you replace it you’ll have a good idea what it was supposed to feel like. Also once the pinion nut gets put back on all the way you will be close enough, at least in my case. With the TQ wrench I got 10” lbs before wheel movement.
Definitely going to need that 2 jaw puller. All in all it took maybe an hour with me crawling under the truck in the driveway wishing for a lift. Lol
Appreciated!
The Car Stereo Company
here, on frf
That's impressive but my brain wires would short out until I cleaned everything before being able to get anything else done. My first thought was I gotta get to this guys shop and clean that up! Lol *ptsd from engine building daddy beating it into me.*
i was in nevada today. you can make it here in a day. the engine bay will still be here
Gumby
Nashville
Finished up my shock rebuild with a fresh set of decal wraps. Now to get them on and see how many miles I get.
First pic shows the TSW wrap compared to what I had made.
View attachment 471087View attachment 471088
Those look great!!!! A little shiny. but I like shiny. Can you send me some? LOL Did you polish the body that well and clear rap them or is the vinyl shiny like that? I have several sets that need stickers.
RAPTORSCHIM
Buckhannon, WV
It's a chrome base wrap with blue stencil.
I agree, they are a little blingy ... Might try a brushed aluminum on the next set.
