TAC71
Osoyoos BC Canada
Started on the rear inner fender liner install along with all the other things I'm doing at the same time.
Picked up regular F150 rear liners and they are close but the outer lip is way wrong.
I took the box off the truck to clean the bottom and rust paint where the liners will be and to make the liner mods easier. I made a quick rack to roll the box around on and to tip it up on end.
Previous owner undercoated the truck and its all good except for the rear wheel tubs which are peeling. I removed all the old undercoat and put 2 coats of rust paint on.
The liners fit the inner box perfectly but the outer lip needs to be flat. I cut off the stock liner lip and fabbed an extension out of flat HDPE. I riveted the two pieces together. The wheel opening lip will be tucked under the flare. I did need to use a heat gun to shape the flat a little to fit nicely on the wheel lip. I will be reinstalling the mud flaps.
TAC71
Osoyoos BC Canada
When you lift off the box there are 2 grounds that need some attention.
Liners all riveted and ready for install when the box is back on.
Next thing to do is roll the box back down and spray in the Raptor box liner.
TAC71
Osoyoos BC Canada
Sprayed the box with tinted light gray Raptor liner. Then reinstalled the box onto the frame.
The fender liners , flares and mud flaps all went together very easily. I made a aluminum mounting bracket to help support the inner lower edge of the liner.
TAC71
Osoyoos BC Canada
Since the rear bumper was off I decided to fix the scrapes and dents in the bumper ends. I banged out the dents and sanded it down for fresh paint.
I found some Prius paint that was a near perfect match to repaint the bumper with.
With Prius paint my Raptor is more ECO friendly.
