blazn5667
Virginia
Anyone in the Richmond, Virginia area that has forscan tool to help be able to adjust tpms sensors to lower psi than factory setting? Not sure correct post but thought I would ask. Assuming stealerships won't do it if asked?
TAC71
Osoyoos BC Canada
Did some checking today with the rear wheel well liners.
From the pinch weld in they fit great. They should, it's just he same as a regular truck.
From the pinch weld out they will need to be cut off on orange line in pic.
The green tape spots are where I will attach the flat HDPE out under the flare. Of coarse, once I get into the job I hope it goes that easy.
WNCHSTR96
Athens, Alabama
LOL! I have always been under the impression that if you go down to the last few gallons you can introduce air and trash into the fuel system and clog or mess up your pump or injectors. I may be wrong but I don’t think it is a good idea, that’s all. I’ve taken mine down to like 6 or 16 (can’t remember) and it still only took 33 gallons!
Truck holds 36 gallons. I put in 35.
Not sure what you are asking.
Bozz
Royal Smart A$$
Nashville, TN
Yeah, I've heard that with many vehicles. I believe the fuel pump in the Raptor sits in a well, so if your down to a gallon, there's probably about another gallon or more in the well to keep the pump cool and lubed.
Oops! I did forget to mention that I only got 27 gallons into the truck and had to put 8 more gallons into two fuel cans to max out my 35 gallon limit on the discount.
