jdm_sixtwo
11MPG is average, right?
Beaufort, SC
Started working at a shop that does alignments which is great because I got a free one from it. Does 6 degrees of positive caster seem bad to yall? Boss has a gen2 and said 6 degrees was fine. I have gen2 shocks and 2-4” length upgraded control arms. Also need ready to switch up wheels and tires cause I found a good deal. So if anyone wants some fuel trophies and worn out All Countries I’ve got em. Need to sell to pay for new set.
jdm_sixtwo
Beaufort, SC
Canuck714
San Antonio TX
Running 5-6 will give you a heavier feel in steering but wont hurt anything.
Better straight-line stability as well.
The Car Stereo Company
here, on frf
I spent hours a couple of nights ago going through every thread I could find about onboard CO2. Today I purchased what I hope I need to use my tank and regulator. Today’s purchase includes a hose, a pack of couplers and an inflator with gauge.
and a co2 machine. so you can fill your tank in the middle of the desert when you find the tank is empty.
Bozz
Royal Smart A$$
Nashville, TN
Changed 16 plugs, wires and coils last week. NOT fun. VERY time consuming. Spent 2-1/2 days doing it. Had a broken coil boot on on of the back ones on top, took 2 days ******** around with it before @Gumby finally came over and took over the ******** around duties. Still took 90 minutes to get that dang thing out of there. Then took 2 hours to do the bottom 8. Personally, I found the bottom ones much easier to do than the tops. Tip for the top ones.....Disconnect wires on coil BEFORE removing, then rotate coil on plug 360-degrees, or even 720-degrees before trying to pull off. This should prevent any sticking of bottom of coil boot to the top of plug.
Used FOMOCO coils, NKG plugs and Carquest Premium spark plugs wires. Truck runs like it's brand new!
