The Car Stereo Company
here, on frf
I dig that big bar. Custom mounts?
i put a bar there but higher up. just took some steel sheet metal and cut it, bent it and drilled a couple holes. it lasted for several years until i took it off because i had too many bars up front that it was blocking air flow to my transmission cooler. i ended up putting it on tirinas truck and she runs it now. simple do it yourself if you want
here, on frf
Yea I’ve never had luck either. Just like the location of it due to theft.
nobody has messed with my lights. i also modified my wiring and tied them int my alarm system, but everytime i come out to my truck, my lights are still there. you can also get security nuts and bolts which make it a lot harder to steal. virtually impossibe to remove without the right tools. and most common theives wont carry them
Irregular F150
its terrain good sir!
May have to find those. Not that ive had an issue. Lol.
BenBB
Lots of different places
+1
Johnny Raptor
LA
Research the Mishimoto radiator, there have been a few that have had problems with it. Poor craftsmanship.
I ended up installing the Full Race radiator and upgraded trans cooler after checking out Mishimoto and reading about the issues. Been 2 years since I installed it with no issues at all.
Just throwing it out there in case it helps somebody else.
Meat2022
Alabama
Clean my MAF today, also changed both batteries on my key fobs. Im going to reset my MPG on next fill up and see if it improves a little. Also with the CAI, only 2 bolts go into the CAI the other two only hold the adapter bracket on with the gasket. Seal is tight but seems like they would design this to use all 4 bolts or screws to ensure the tightest seal.
