Sage
WA, dry side
I didn't remove the differential cover. I used a vacuum pump from Amazon. Took a while but I got all of it out. I had a plastic paint mixing bucket with a measure scale on it. I used Valvoline oil which comes in a bag. Refilled until it ran back out.
Transfer case was easy. I put an old icecube tray under the drain and tilted towards a bucket. Didn't remove anything except the plug. I used the same pump I used to remove oil, to refill the transfer case. ( Thoroughly cleaned before using it to pump different oil back into the case.)
I will use the same pump on the front case.
