MTF
Celebration, Florida
I've had a pesky "check fuel inlet" gripe that keeps popping up with no real trend. I tried actuating the door and spraying some WD40 in there but no avail.
Now that I'm writing it I suppose I never pulled the negative terminal, may help reset it.
You need to clean it first with carburetor cleaner, and use the white gas insert nozzle that under the rear seat and insert about two dozen times while spraying.
WD 40 is the worst product you can use as a lubricant, it's a cleaner/nut buster. And does not lubricate.
Look for a real silicone lubricant not a nut buster.
If you have already used WD 40 in there, you probably have rusting going on now.
Just keep cleaning, and don't use WD40 crap.
badm0t0rfinger
Rocket Man
The Beach
Yes, I cleaned it first. I cycled the gas nozzle like you said.
I merely autopilot when I typed WD40. I'm a PB Blaster guy anyways. I used seafoam spray.
I'll go through it again.
yoopercharged
Tri Cities, MI
Got the rpg brackets installed. FYI not a fun project to do alone LOL
I had the hardest time with my SDHQ brackets. We marked the hinge positions in advance and still couldn't get the hood realigned correctly, even with the second set of hands. After about an hour we finally got it to clear but the panel gaps on either side are off. Oh well.
Irregular F150
its terrain good sir!
Yeah I definitely marked them too. Mine may be off but i got it to a point I couldn’t really tell.
I used a broom handle and the wall i was near to hold the hood up enough so i could get the bolt tightened with one hand, while the other held it alined. Lol.
