Cody Templeton
Des Moines, IA
Received my reflective letters for my grill from Rocky Mountain Graphics. I’ll post some during application and after photos later.View attachment 374689
They make awesome vinyls. I have had two of their grille letters and two of their hood decals as well as the fender vent decals and they have all been absolutely awesome.
Irregular F150
its terrain good sir!
Get the leds hooked up but when put in reverse they all flash on and go out. So i guess they draw to much.
Anyone know if the trailer light harness is the same circuit or separate??
I really do t want to run them to a switch if i dont have to lol
Cody Templeton
Des Moines, IA
Might have to reflash the BCM with FORScan to remove the bulb out indicator. I did that with mine very early on and haven't had an issue.
Irregular F150
It reset after turning the truck off then back on. The oe reverse lights work with out the bumper lights. I hooked up one and they bulbs dimmed but both bumper leds it shut off.
Where do i get this forscan, ive tried to look into it but only see a download. Is that all it is or some handheld device?
Cody Templeton
Des Moines, IA
Mine are wired into the trailer reverse circuit as well as Aux 4 and they work just fine when I put it into reverse. I'd assume you need to remove the bulb out monitoring from the BCM so it doesn't shut off.
Irregular F150
The trailer wires worked out. To bad I ended up cutting through one and now need to find more wire to repair it before i haul a trailer lol.
TAC71
Osoyoos BC Canada
What "air system"? An onboard compressor?
A Viair 150 psi continuous duty compressor. Mounted an air tank and connected it ti SW2. Rerouted the ground for SW2 relay through a pressure switch on the compressor manifold. Compressor has a cover for when not in use.
Cody Templeton
Des Moines, IA
I was thinking of running two of them with an air tank. You think 1 is enough?
