SVTRap
Big Sky Country
how do you determine if you have select shift auto? How much was the new wheel and how tough is the install ? I guess if the battery is disconnected the airbag is not going to fire ?
Can't remember if the early Raptors had it but easiest way to tell is to look at the shifter:
+/- Adjustment is an indicator
Steering wheel M-3600-F15RRD was $423.00 shipped through Summit after they beat the price SDPC had it listed for.
Install is straightforward once you disconnect the battery and wait around 20 minutes (or pull the fuse). Only thing that can be slightly aggravating is releasing the airbag/horn pad but once you do that then its just one center bolt that holds pressure on the wheel, no removal tool required.
Kaz109
California
3 days in the Utah and Nevada desert that ended today, now taking it to Yellowstone
This was the first time off-roading out West and I was surprised how some of the trails where you could open it up for so long. Running 80-90mph for so long that I had to constantly watch temps because I went into limp mode 50% power. Granted it was about 100 out each day, so that didn’t help
Are u 100% stock or did it go I to limp mode even with aftermarket IC?
