ogdobber
That’s ******* awesome is that on your Raptor?
Yes. On Amazon for $65 now (1/2 price when i originally discovered) ebay they are still $90
https://www.amazon.com/dp/B00RAOIIBC/?tag=fordraptorforum-20
Note* the f90-tpx is for the 10-14 raptor even though amazon says it doesn't fit. Well it doesn't fit with tailgate stripper pole
Edit* actually it could work as a pole delete, the metal filler piece from ford is a couple hundred bucks now
Deleted member 12951
Guest
Just cancelled the Corsa order and ordered an aFe muffler instead. Going with dump style for now and if I don't like it then I'll hit a muffler shop to get me piped out by the rear tire. Spent the savings on a Power Stop brake kit instead.
MBRP Turndown with a resonator is what I run. I was running without prior. Best one I found for off-roading. I used to have the Ford Performance made by Borla but kept ripping it off.
Freedom Motorsports R1 Brake kit is the best for our Raptor for an OEM replacement, run those too.
Jonny V
Carnation, WA
After changing my mind three times I got things figured out... I cancelled all the Corsa stuff. It just really seems like a waste of money. Instead, I'm going with a dump style exhaust using MBPR resonator and muffler, and also ordered up a Power Stop brake kit as my brakes have 76,000 miles on them and I'd rather get it done sooner than later. I will have to hit a muffler shop and have them weld on a hanger or two, but that will be minor. Thanks to RDFTS for helping me on this!!!
All told, I got exhaust and brakes for $1300, which is just a little more that what the Corsa kit was going to cost. There's going to be less clutter around the rear end which will make things easier when I install the Icon springs and SVC adjustable bump kit down the road as well. A good bit less weight too, every little bit of that will help!
In the meantime, I took the truck out blasting up and down some country roads on open pipes this morning...I highly recommend cranking the stereo while you're at it too!!
ogdobber
Took off the rear ROGUE bumper to replace with the SVC V3, got SVC to do cut out for the chase s2 baja light. Had a big hand from Ryan to get everything uninstalled reinstalled and dovetailed. 1537b6c33a2f77a11f7e56ecf09ac45e.jpg9799ad20b8fac005d14ff47e5b1d948e.jpgabd0f37c00f71be5d5e7685e82287bd2.jpgc64aef04e97508fb25e7eb63aa5fd004.jpg735617bd1a0a978d5c43ea67fac0c548.jpg6ebfe3e8ae1e878086ce51c25bf8a5b9.jpgde7d62ceac7b41c4cf1a019a19e9fa5a.jpga12bfdb199c6b94451beba20faccf5d9.jpgf075005698763e92de3ad5845bc30284.jpg45b913f43bf20ad3ef8cc81cfaa8cd5b.jpg1a91ccba121539e68b2cf3de47ea9cbe.jpg2028295781434a3f248d09e48e4615bb.jpg
Sent from my SM-G960U using Tapatalk
That might be my favorite rear bumper. The front you have, is that a frame cut?
