trophycummins
Simi Valley, CA
Coated svc bypass rack in steelit
Coated diff in steelit
Svc ABS bump kit
Deleted member 17706
Guest
What all have you coated with steel-it?
DP
I am using it on my LCA’s. The stuff works great! It is very similar to AMSOIL HDMP in regards to how functional it is straight out of the can.
https://youtu.be/LnLSHVQobHo
---------- Post added at 09:49 AM ---------- Previous post was at 09:45 AM ----------
Svc ABS bump kit
My only regret is not coating all the suspension components before I had them installed on the truck. Lol it is a pain to coat everything on the truck, but it is well worth it!
Dozer466
TX
Are you sand blasting your parts first or just sanding them?
Dozer466
TX
I shoot that stuff over everything and hasn’t flaked off yet. I usually hit it with scotchbrite and brake cleaner and shoot the steel it right over it
Nice, I’m going to do my upper and lower control arms since they are starting to rust a little from the powder coating getting blasted off.
daveypetey
Did you do any of your frame? Rocker panels?
Guest
No, I have not. I use AMSOIL HDMP for my frame. I pressure wash the underneath and body panels of my truck. Here in the coming months, I am going to Kevlar the entire body of my Gen 1.
I am sure you would have no problem using STEEL-IT on the frame. Very easy application once you clean the surface of the object that you want to spray.
