Chiefapple
Milwaukee, WI
Sent from my Raptor using Tapatalk.
Pyro3601
Lethbridge Alberta Canada
Took advantage of a slow shop and the hoist and finally installed my rear diff cover. The bolt that come with the cover are weak sauce. Broke three trying to hit the proper torque spec. So ended up running the original bolts. They where the same length.
ogdobber
piaa sae fog light. saw these on a trophy truck last year. i like the fact you can't see the leds (reflector instead) really bright and precise437a5e65b385e6ead9d327275ab6d858.jpg
Sent from my SM-G950U using Tapatalk
t_j
Chicago, IL
Put on my geisers and dropped to low perch. Mid perch height with low perch ride. What a difference.[
Good call on the perch change, this is what happens to top hats when they are set to mid perch with those springs:
Good ones for reference:
AndysLog
Moro IL
Transmission service; glad I got the filter with gasket just in case, the factory gasket had some rubbery material missing around some bolt holes...hopefully the transmission ate it and they aren't like lodged in the thermostat or valve body somewhere. Added Saudi transmission cooler, ready for summer...
saudi trans cooler is bigger?? have a part number or comparing temps?
BenBB
Lots of different places
Yes I think it's a 6-row versus the stock 2-row, this thread is one that covers it in depth, thanks to @vanilla_gorilla for posting the part number on the last page. I ordered mine from Tasca as well. Haven't had the transmission temp even high enough to open the thermostat yet (185°?) but hopefully soon I can see how it does, was bumping 215° last summer and not pushing it too hard.
SVO 85
Portland, OR
Finally got my truck back from my dad. Wheel bearing turned into wheel bearing, IWE, CV boot, shock rebuild and upgrade (thanks Forged Off-road) mid perch and 4 new focal speakers cause why not. Glad to have it back.
