waddellw
Mississippi
This will be the 7th day in the body shop getting fixed up, had a car hit me a little over a year ago seriously damaging the driver's side, mostly the driver's door but also broke the running board in two and scratched the whole side of the truck.
Nice to finally be fixing it up! I'll post pics whenever it gets done.
Hate not having my raptor but at least I've got another raptor I can jump into every now and again a 2018 leadfoot.
Dig the new one and the old one. One thing that seems wierd to me is how much higher I'm "forced" to sit in the new one, the seat doesn't go down near as far!
Sent from my Pixel XL using Tapatalk
Clockton
Northern CA.
Did almost everything on the list last weekend at SVC and then went to Mojave
ineedaBubble
Swansea,MA
Did you get your situation squared away with the title and plates? Can you finally drive it? I would also suggest switching parking spots with your wifes car. The hanging bike would drive me ******* nuts. Its damage waiting to happen
Not sure how I missed this the first time, but I only just now saw your comment about the bike. Ha! I DID switch spots with my wife. She used to park on this side of the garage. But the truck takes up too much room for her to squeeze by with her 8 month pregnant belly. The bike has been up there for 15+ months, it's not going anywhere. But I can absolutely understand your apprehension, lol. I may need to do some reorg with the cabinets and fastTrack systems in the spring, anyway, so the truck fits better with more room around both the front and rear of the truck.
Toadster
Folsom, CA
added coolant/trans temp numbers above gauges with Forscan :biggrin:
Engine temp & Transmission temp shows above gauges (8" Clusters only) IPC 720-07-01 xxxx xE5x xxxx ** use this if you have trailer brake controller and turbos **
need to figure out how to get the Oil Temp to show now...
oplersx
British Columbia
Yes, AGM. Not sure about SEARS, was tod this NorthStar is a bit better than Odyssey 1750T for $25 cheaper. Hopefully it is...
4 years full replacement warranty
1750 pulse cranking amps
1070 MCA
930 CCA
650 CCA At -29 C
135 reserve capacity
69AH rating
Is that an AGM battery? It looks exactly like the AGM that Sears used to sell a few years ago. That was an awesome battery!
R,
HAP
BenBB
Lots of different places
New windshield, rotated the tires and put on some Gorilla lugs (stock lugs SUCK), changed out the power steering pump (hadn't failed but at idle it whined louder than the exhaust). Built some rear shock tools. Ordered balljoints and tie rods...
