The258
McAllen TX
Intake pressure, exhaust pressure, shock pressure that's already 4, and volts for all the lights getting hooked up.
J DAMAGE
NJ
Seriously, what 7 things do you need to keep your eye on that badly.
Not badly , because I want to.
Volts
Trans temp
Oil pressure
Oil temp
Water temp
Wide band air/fuel
Vacuum.
I know oil & water will be close but , going in anyway, one may be replaced with my air gauge for my onboard air.
Trick.Raptor
The Cracker Raptor
Santa Maria, CA
I had no idea they were offering these now. Definitely cheaper than the SDHQ alternative that I have, look identical though. See you opted for the double sheer option for down the road. So when are you upgrading the tie rods?
My tie-rods are worn and need to be replaced right now (along with my converter seal). I'm just going to have them replaced under warranty for the time being.
Next round will most likely be from my guy at WOG.... the Blitzkrieg Motorsports Tie Rod Kit though I do like the RPG one as well..
RLTW
TX
Volts
Trans temp
Oil pressure
Oil temp
Water temp
Wide band air/fuel
Vacuum.
Gotcha, looks like it'd appear too cluttered for my tastes, but I hope it comes out clean.
J DAMAGE
NJ
It's sitting at 5" , not to bad, but you are correct, it can take on a whole different look with gauges installed, if that is the case I will end up putting 4 there, and using the A pillar for the rest.
t_j
Chicago, IL
I went with the SDHQ ones myself to go with the knuckles.
These ones seem to be the SDHQ ones with installation, way cheeper than the SDHQ installed version. Seems a little cheep TBH as the install is a hugely labour intensive process if done correctly.
