madmex
South Texas
Did a few small MODs: Installed the OEM ECU connector cover. A very functional but a cheaply made component. This item is a perfect candidate for someone to offer in an aftermarket improved form. Perhaps a reversed cast Carbon Fiber version or even 3-D printer version would be desirable to me. The dealer wants $46.00 and its made of some sort of polystyrene... I found one on eBay for $20, but its still a poor value. I also did the Garage door opener visor upgrade, bought the whole visor also from eBay. And finally the drivers side frame wire harness move. That took only about 2 minutes.
R,
HAP
Do you happen to have a link? Can't seem to find it by part number.
colticus
Here's a quick of the drivers door.
The little Sony tags come off. They're just held in place by some little bent over pins that all broke off when I removed them. So when I reinstalled them I bent over the middle centering pin and hit them with a little epoxy.
That looks good.
Just regular spray paint?
fjcoop
Did a 50K service. Noticed that a have torn dust boot on the driver side steering arm. Not sure what you call it. Do you think my ESP will cover it?
Floyd91
That looks good.
I ended up using rustoleum satin black after going to 4 different places looking for krypton fusion. I did a few light coats on the front and edges and then one on the back just to be sure everything was coated.
Yukon Joe
Trafford, PA
Did a 50K service. Noticed that a have torn duct boot on the driver side steering arm. Not sure what you call it. Do you think my ESP will cover it?
I doubt it. The tie rod boots are about $30 a piece.
New uniballs upper and lower on the passenger side, that AGM uniball tool is worth is weight in gold. Drivers side tomorrow morning.
Do you have stock control arms?
@Yukon Joe :baby: :baby:
www.runraptorrun.com
