NC Raptor
Charlotte
Huh?
---------- Post added at 07:10 AM ---------- Previous post was at 07:07 AM ----------
Yes if you get the upgraded ones with the doubler plates. Plates are put on both sides, you get 8 of them and will increase the thickness and a longer bolt is needed. Its a different design than the cam kit that you get without doubler plates. Supposed to be stronger bolt than OEM too.
Correct me if I'm wrong, but if I understood correctly when I ordered them, the bolts you receive are longer whether you get the weldable doubler plates or not as long as you get the package with upgraded hardware because it says on the page "These new alignment cam kits will work with our Lower Control Arm Doubler Plates as well" and when I installed mine with the upgraded hardware their was still roughly 5/8" - 3/4" of threads exposed even with the additional space added by the cam plates and washers.
Raptor Alignment Cam Kit with Grade 12.9 Metric Bolts
@Yukon Joe
Deleted member 12951
Guest
@Yukon Joe
That is the upgraded one and you are correct. The regular cam kit doesn't come with bolts and just uses your OEM ones.
Ford Raptor Alignment Cam Kit
F1dadaa
Los Angeles
Saw this truck on the lot At Allen everyday on the way to the shop and was wondering when someone was going to pick it up! Congrats.!!
Thanks! Yeah i had my eye on it for a while but waited until they reduced the price to move it. Then i came in and made it mine.
ossachuk
North Western Ontario Canada
Took my puppy for a cruise and wash
