Ramathorn178
Selah, WA
Icon bump stop kit went in :). Only suffered a gash on my pinky from the exhaust bouncing back into place against the inside bracket. 1 small extra bolt and washer where I have no idea where it goes from hardware bag one.
Ditchplains1
Trescott, ME
JanT,
When I installed mine I was the butt of endless sarcasm because the slots and drilled rotors were oriented as on Raw Horsepowers'. Further reading showed that the slots and drilled pattern are not as important as the vanes between the two sides of the rotors as diagrammed on my first post. If the vanes are radially oriented no big deal either way. If the vanes are directional the rotor should be positioned so that the heat generated is directed outwards.
Most rotors that I have seen are properly installed as on my diagrams.
Clearly Raw Horsepower's rotors were intended to be installed as he has...as indicated on his instructions. This is the first time I have seen rotors with the venting installed in this direction.
Live and learn!
Eddie
Ramathorn178
Selah, WA
Well woke up this morning and remembered where that 1 stupid **** bolt was suppose to go (passenger side inside bracket where you put the clip into the frame). Then went ahead and put the install date and mileage so i know when they are about due for rebuilds. Defiantly sad that the pretty aluminum bar will now never be seen.
SVTLOPEZ
I was installing LED lights in the vanity mirrors when I'm the process I broke the stock bulb trying to get it out! POS. Anyone know how I can take out that bulb? Lol
