AdamsPolishes
I found I couldn't get it done fast enough after washing it and leaving it wet. It came out kinda gloopy from the bottle and was spotty. I shook it really good for several minutes so not sure why it was coming out like that. Is it supposed to? I ended up getting an empty spray bottle and filled it with distilled water and used that to wet the panel, apply H20, rub in/off and then polish out with a super plush towel. I saw a few streaks if it dried some but a quick spray of water on it an polish it out made it come out great. This was my first time using it so I am sure it will get easier.
It does spray gloopy, as it is a thicker product, but since it has to be spread around with the wet towel, it should not be an issue.
Sounds like you are figuring out what application method works best for you. I found it does take a few times using it to come up with a routine for what works best for you.
-Dan
Wilson
South Dakota
did you watch the video
http://youtu.be/cdVpa6jz08c
RLTW
TX
Removed the KHC spare tire carrier and mounted the jack. Probably a temporary spot, haven't decided. Will wait till the bypass rack is in.
Whose jack mount is that and what tonnage is that pb jack
SlimChaChi
NJ
2 ton and the mount / skid is by DMZ fabrication. I debated where to mount it for a bit. Not sure how I feel about the location but I'll leave it be till I get the bypass rack in.
Rodbender
Woodland, Ca
I got my custom cnc SVT engraved flush center caps about 3 weeks ago. I ordered them raw because I was going to have all four of them along with the 96 cosmetic bolts on my new Method DS wheels powder coated Red. I got the caps and bolts back on Friday from powder coating and had my buddies wife paint the SVT black so it would pop out. Installed them yesterday at the house.
Happy wife happy life
Ramathorn178
Selah, WA
Cough* yesterday *cough* need to straighten my drivers side frame horn still. I'm now also looking to get it linex'd and to balance out the look getting a rear bumper. ******** this shit just snow balls.
dataustin
Went into the FORD dealership to get the 'Rock's' 31 point inspection along with the oil changed and ended up getting brake pads on all four wheels and rotors on the front wheels plus flushed the brake, power steering and engine coolant. I got 136,000 miles out of all of the above, so not too bad. Going back tomorrow to get the rear seat latch replaced...
