Weird shake/shudder while decelerating
tooldrmr2009
Fort Wayne Indiana
I am noticing strange behavior from the transmission as well. In normal mode and sport mode it does feel like a hard downshift. My wife even commented on it. I wasn't planning on doing a tune, but if a tranny tune will smooth this thing out, then I might as well. Still under 750 miles, so holding hope that it is "learning" and will smooth out over time.
I got 350 on mine and it shifts smooth in normal mode both up and down. Sport mode for me is very aggressive shifting almost shudder and banging. Dunno if it's still learning normally for 500 miles it does. I've been leaving it in normal mode to learn more and try later but everything for me is ok.
uscraptor51
CA
Does it make a difference if you are in 2H, 4H, 4A…? Is the differential locked? I noticed when I first got mine off the truck and took it for a quick lap it was in 4H. Another time when I switched from “Normal” to “Sport” it somehow also switched from 2H to 4H (thought that was a little weird).
Maybe try to isolate the vehicle settings (you can take a photo of the Raptor Info screen which will show all the settings) and if you are making changes via the steering wheel buttons or the “Drive Mode” dial?
ganooch
Dallas, TX
Yeah, I think it happens more in sport mode. Let's hope things smooth out over time.
tooldrmr2009
Fort Wayne Indiana
No worries be curious to see how everyone's pans out after 1000 miles or so. I'm giving mine a good look over tonight to make sure no issues arrise like everyone else has kinda had. Maybe I'll dive into my interior issues tonight before I start an unnecessary warranty ticket at work while I'm trying to find root causes for stuff :angry94:
ganooch
Dallas, TX
What interior issues are you seeing? I have given mine a good inspection and the only faults I have found were dash trim pieces not seated all the way in some areas. They popped right in.
tooldrmr2009
Fort Wayne Indiana
Got a thump/thud from RF seat when someone sits in it and I take off from a stop. It's so annoying. Sounds like seat frame or base is loose. And rolling down the road I got a metal clip rattle from the rear seat area just driving straight and steady down the road.
ganooch
Dallas, TX
Ugh, those are annoying. Hope they are an easy fix.
maccabee
maccabee
OH
I would try manually shifting the transmission when slowing down and see if the problem persist, if not, maybe there is a reflash or something for the transmission. If this doesn't change the issue, then it maybe another component such as a torque converter. Could also put it in neutral and let it coast as well, just to rule out driveline components. Document everything and have it written down when you take it in for service. Good luck, hope it is nothing.
That’s a great idea, thank you. Will try this and report back.
Wackem1
Florida
Same thing happened to me yesterday I noticed when braking! Only happened a few times. But definitely caught my attention
96,436
60,366
jinshaohaw
Latest posts
