Watch A Ford 6.2 Boss Engine Which Now Measures 460ci Scream At 8,500 RPM
Jimbo
Mad Frog Mattis
IL
Ah F@CK! Another mod to add to the list...thanks :flipthebird: LOL
---------- Post added at 10:39 PM ---------- Previous post was at 10:36 PM ----------
He built something similar...maybe not quite that badass...it's in Smurfrunner.
I know... I heard that beast around the whole damn track at TRR.
Aramco Raptor
Montreal, Canada
There is a good chance I will be sending my truck to SVC for a shit-ton (my favourite unit of measure) of suspension mods.
I'll have to try to time it so I can go on one of these runs with you maniacs...the landscape down there was built for Raptors.
Dv8tor
Detroit, MI
If that's what Roush came up with for a naturally aspirated version, I wonder what MMR can do with the 6.2L. I'm glad there's finally a dry sump oil system made for this engine though. Bout time.
Aramco Raptor
Montreal, Canada
Where does one buy one of these
I was just pricing this sort of thing...
Patton Racing Engines has freshly re-built Trophy Truck strokers, slightly de-tuned to run on pump gas, 650 hp, dyno tested, with MOTEC engine management systems...roughly $25k - $35k.
Their website is under construction but they use Facebook quite often it seems...and there are some engines up for sale on there.
I'm seriously contemplating swapping out my 6.2 for one.
Good luck.
Truckzor
Good luck.
What block are they based off of? Will they fit in the engine compartment? If so, would custom parts be required to mount? (engine mounts, bellhousing, accessory drive, etc.)
The other problem with options like this is that most of us still want to be able to drive on the street (legally) and need to be able to pass state inspections to do so. I'm not sure how that would be possible if you weren't using the factory computer.
If nobody is going to really go after the 6.2 market then maybe it's time to start thinking about an LS swap. There, I finally said it.
If you started with an aluminum block, you'd save a bunch of weight over stock, which is something our trucks really need, and LS motors make tons of power.
