VisionX Xmitter Xtreme Lower Grill LED Kit
ARH1956
NE Alabama
No sir you just remove the lower center grill plastic insert. No cutting required
No cutting but you will probably need to bend the upper tabs on the bumper the lower grill inserts bolts onto. It takes 30 seconds and they can easily be bent back into place if you decide to reinstall the grill.
Gsteve
It looks like you could make a cleaner lighter looking install if you were to cut the old insert to fit and reinstall. There is not enough room at the bottom so the whole bottom section would have to be cut off , leaving the top and three sides in place. Im going to make a plate to cover the bottom tabs and gap.
AlternativeOffroad
Los Angeles, CA
if you make that work, let us know!!!
Gsteve
Will do ! Is level the best way to set these up? sure is wayyyyy bright in the first 6o feet.
ARH1956
NE Alabama
I have the original silver powder coated mount and it looks perfect. Adding part of the original grill will look far worse than it currently does, IMO. The gap on the sides of the light on my truck are less than those on the tow hooks, and the light is exactly centered vertically in the opening.
