Hi all - installed Fuel Hostage 20x0 rims and new Toyo R/T 35x12.5x20. had both a vibration at lower and higher speeds as well as a loose on center feel. dropped pressure to 40psi and the on center is better but vibration still there. gets rather choppy. switched tires to New Nitto Terra Grappler G2, and it was worse. Feels like we are rolling over a bed of identical rocks. Switched back to the R/T's and although a little better, same issue.
Did some research and only thing I can find is that wheel is lug centric, not hub centric. We are using the hub centric rings of course and not improvement. Dealer offered to swap wheels (they are fantastic with customer service) but before I do that, does anyone have any solution or idea other than ceramic beads (don't want the noise)....
I've had wheels/tires balanced 5 times, both at original wheel dealer and Ford Dealership and on Hunter Road Force. Ford shows the wheel dealers balance to be off by nearly 4 ounces and vice versa, however, truck drives and vibrates same either way, which makes me suspect the wheels. When Ford balanced last week, we all watched inside of wheel spinning and where the spokes meet the outer rim, it rotates oblong like. Balance should take care of this, but it's not.
I'm at a loss and it was hard enough for us to find wheels we liked on the truck and hate to do it again. Any suggestions and do other Hostage owners or other fuel wheels have this issue?
thanks in advance for your help.
