- Joined
- Aug 4, 2010
- Posts
- 1,071
- Reaction score
- 661
Here's mine just done today by River Oaks stereo in Houston, Tx
email the guys at the antenna farm or rugged radios. They will get you squared away, Rugged over antenna farm.
they will also explain zero plane, and non zero plane antennas.
Definitely not going to do it myself I for sure do not know what I am doing
With all due respect. SCREW Rugged. Those guys are ****** bags.
For VHF only, you need an NMO mount (magnetic is decent). Hole in the roof is better. and an NMO base antenna. Get your antenna as high up as possible (on your roof). 1/4 wave is about 18" or 5/8 wave which is about 48". They both have their benefits. 5/8 has more range, 1/4 doesn't bang trees and parking garages as bad.
Dual band antennas to look at.
High Gain Dual Band Antennas : The Antenna Farm, Your two way radio source
Quarter Wave Dual Band Antennas : The Antenna Farm, Your two way radio source
VHF only antennas to look at.
High Gain VHF Antennas : The Antenna Farm, Your two way radio source
Quarter Wave VHF Antennas : The Antenna Farm, Your two way radio source
The radio install isn't that bad. It needs to be wired directly to your battery for best results. Did you buy the radio already modified to TX on all frequencies? If not your going to need to clip out a diode to make it TX on the freqs used by the Runs. Google Icom IC-2820H Mod to learn how to do it.
If you need any help, feel free to PM me.
---------- Post added at 10:01 PM ---------- Previous post was at 09:54 PM ----------
Also. The 2820h is a ton of radio. Unless you're planning on becoming a HAM, it's far more than you will ever use. I'm assuming you picked that one because of the detachable face? I have the ICOM 880-H and it was about 200 less with a bunch of the same features.
As far as programming, you can download software from ICON for free for that radio, and buy a cable online. But the good thing about that model is that you can field tune to whatever frequency that falls within the radios range. So you don't really have to program it at all, except for convenience.
