VDM Module Replacement - As-Built Values?
Drivin2Fst
Drivin2Fst
Chicago Suburbs
Sorry to hear that. Have you run a Self-Test on the VDM with ForScan?
I did with the values that were on the new VDM and it did not pick up any readings. With the as-built values it did give me readings for ride height and a few other lines but still rides like a box truck.
FordTechOne
Detroit
Well the VDM On Demand Self Test I'm referring to will report any DTCs that are setting; so I'm guessing there are no DTCs?
FordTechOne
Detroit
There were no DTC’s showing in Forscan.
That is even more strange; if the module isn't programmed correctly it should at least have DTCs for module configuration incomplete. Does ForScan have the option for Programmable Module Installation (PMI) like IDS?
Drivin2Fst
Drivin2Fst
Chicago Suburbs
I don't believe so. At this point I'm going to leave it up to my dealer to figure it out. They need to figure out the oil issue as well now. Hopefully the 4th try is the charm.
sixshooter_45
Arnold
Sounds like it's time to try another Dealer.
