dude, I've owned 4 different ecoboost trucks. I like the motor. I think it is great for most folks.
That being said, throttle by wire creates delay. you may not catch it, but when youre pushing at 8/10th or 9/10s that .5 second matters. The same goes for turbos, even if it is low lag, it is still lag.
as far as engine braking, 2 less cylinders makes a big difference. The trans strategy also makes a big difference. Even when manually shifting in baja mode, there is a weird delay in the trans actually shifting.
for my porpoises
, I'd like a v8 with easy Revs, most of the torque in the first half of the power curve and a trans that shift very quickly manually ( like a PDK or sequential air shift) or a really good trans program.
The computers in these trucks screw with all sorts of things that I'd prefer be direct input.
Try this:
try to find terrain that makes the truck "wiggle" side to side when holding the steering wheel straight. ( I've found that soft sand and silt make this the easiest to feel)
Now, when you hold the wheel laser straight, the truck with wiggle and ride the ruts.
as far as the experiment, stomp on the gas, then wiggle the steering wheel side to side like this :
do it from 11-1 oclock on the wheel.
Now notice that stability control kicks in, the computer applies braking, modulates the throttle and the truck is no longer wiggling, it is driving straight as an arrow.
it is like the logic in the computer is completely backward.
some of the features are genius, many others are super intrusive. A V8 would provide the desired driving experience a bit better IMO.
now for a daily driver, I have zero issues with the ecoboost. I dont daily my truck and havent dailied it for at least 18 months now. its an 18.
