Upgraded trans cooler from Fordparts
doktor
Austin TX (Area)
What's the difference between the one from Superior Solutions and this one?
You got me. The Superior Solutions part is a machined unit with no moving parts. It allows full flow at startup. This is nice in a few ways on top of maximum cooling, the first one is you can check your fluid level at first startup because fluid is flowing to all parts. With the factory thermo, you aren't supposed to check until the until fully opens around 200 degrees. That will take a long time idling in your driveway.
The picture you are showing looks just like the factory unit I replaced. Maybe the one you've pictured has a lower opening temp?
Cody Templeton
Des Moines, IA
I really am not sure either why they would look so much different, or what the difference between them is.
HAP
NE NC
I read somewhere that the ECM limits torque until the trans reaches a certain temperature. So, if it never gets there with the thermostat mod it might drive a little different.
R,
HAP
myersroofer614
203 is pretty good. You have to remember the fluid circulates through the radiator first. This is done to get the fluid up to operating temp quicker, heat exchange occurs between the engine coolant in the radiator and the trans fluid. The bad part is as the radiator starts to heat soak under load it puts more heat into the trans fluid which is then extracted via the secondary trans cooler. Towing puts a lot of heat in the truck, its going somewhere, if the airflow can't take it all out it's going somewhere else.
Also, the OEM temp sensor is in the valve body, this location isn't a good indicator of return temps. If you want to know how much change your actually getting you would want a sensor mounted in the pan, or in the return path.
The valve body is in the pan. I just did mine, solenoid 4 TC went. Then me valvebody has 3 bad solenoids n fried my trans. Fun stuff
neovenator
DFW
Sorry for the bump. I plan on adding the Super Duty cooler. I recently got a transmission fluid change. Do I just simply fill up my new transmission cooler with fluid to recoup the loss?
