Upfitter switches not working
HUSKERHOSS
I have a 2017 Raptor and went to hook up some lights. I had no power to the left bunch of wires under the hood. Also, none of the upfitter lights light up, the words AUX 1, Aux 2, ect., on the overhead console. I hooked up a power meter to each of the 6 wires under the hood and all were dead. The lights would work if I hooked up directly to batter, but not to wire. Shouldn't the individual AUX lights have light up on the overhead console light up? Seems like something was not installed correctly. Do I have to do something to make them hot?
Piranharaptor
Make sure ignition is on. There are 2 sets wires ( 2 bundles, 12 wires). One set are hot, one set just goes back through the firewall (so you can hook then up to hot and run something from inside).
Hope I just saved you some stress, phones calls, bad words, etc....ask me how I know.
H
HUSKERHOSS
Thank you for your response. Yes, using the correct bundle and ignition is on. That is my problem, neither set is hot, understand only ones on left that go to aux. switches are supposed to be. Something has to be wrong as every one of the 6 switches on console does not light up.
Aaron
Meme Corps Commandant
WA
I'm assuming you've checked your fuses for your aux switches? If not, do that.
