Normal cruise not working
SouthTxRaptor
2020 Raptor Screw. Relocated my adaptive cruise control due to a bumper upgrade. Adaptive cruise control worked for 200 miles, then it stopped while going 75. Pulled grill back down and saw that my wiring harness was rubbing the back of the grill and exposed one of the wires from the 8way connector that plugs into the ACC. Now I get pre collision not available warning and when I go to the Cruise control option on my dash display it is “grayed” out and won’t let me change the selection ACC to normal cruise. Thus, when I press my steering wheel cruise buttons, nothing happens. I am waiting on a new harness but has anyone experienced this before? Could this be a bigger issue like a short somewhere from the wire being exposed? I checked the applicable fuse and was good to go. No other warnings or check engine light. Weird that I can’t select “normal” cruise or that cruise won’t come on at all when I press the cruise button on my steering wheel? Any help would be awesome.
Do you have that part number on the harness by chance? I’m running in to the same issue worked for a little bit but now grayed out. Thanks
ReedsRaptor
Spartanburg Sc
Wow, all this just happened to my 2019. Ran great, parked, worked two hrs, start truck and dash is going crazy with same codes. No cruise and gotta wrench on the cluster. Fordpass sent a message to see dealer as soon as possible. Just seen this thread is fairly old, did you get the issue resolved?
