tweeter crossovers
greatone99
ma
anyone know what the stock tweeters r crossed at ,i know its a cap but could not read the uf on it
The Car Stereo Company
here, on frf
i would say higher ,as the front is basically a 3 way way front. i removed it it could not really tell it was removed ,so im betting 5000 hz
considering in the gen 1 2 way system, the tweeters were visible down to 1600hz, i have a feeling they went lower than needed for more overlap in the midrange frequency. thats why it sounds like crap when the volume is higher
G
greatone99
ma
The fronts in the unleashed r a 3 way
Woofer , door , mids dash , and tweeter a pillar . From what I can tell , the doors r 200 , mids r 120-5000 , tweeted r 2500
here, on frf
2500 is really low for a tweeter. generally about 3500 is as low as you want to go, however this is an oem system we are talking about
G
greatone99
ma
I actually did some testing the oems have a 7.5 cap the tweeter is 4 ohm , crossover looks to be 5000 so at 2500 hz should be 6 db lower based on the first order capacitor, then 12 db lower at 1250 hz .im going to use a 10 uf cap @ 4 ohms should be 4000 hz crossover
here, on frf
probably want a steeper slope. and whats the eq curve?
G
greatone99
ma
def would like 24 db slopes ,but thats later ,right now just changing tweeters ,and adding and under the seat sub package from sound s good stereo .going to see how this sounds and go from there ,dont want to go down that road like my 2019 , i spent like 12000
