Turn on rear camera lines and front camera
JLopez
DC
Have a 13 raptor with 801a package, previous owner upgraded to sync 3, but the rear camera lines don’t show up, the ones that turn when you turn the wheel. Also, the front camera doesn’t turn on when going into 4l or the off road mode. Went on forscan, disabled and enabled the front camera, and calibrated the rear, but neither worked. Any help? Don’t want to take it to the dealer if I don’t have to. Code throwing is b115e :55
arobertsmith
Lake Havasu City
Interested to hear if there is a solution to the front camera with Sync 3. I also have a '13 801a and would like carplay, but have heard mixed info on the front camera after the upgrade.
Are you also 'enabling' the camera in the dash using the steering wheel controls under truck apps? I would also try the standard sequence and then put the truck in reverse and then drive. I have read that someone with sync 3 had to do that.
kocher93
CA
I did the Sync 3 update on my 13. The lines don't show up after you swap to sync 3.
For the front camera you need to enable rear camera delay in the sync options, Sync Settings → Vehicle Settings → Camera Settings and Enable the delay setting.
Then go through the motions for enabling the front camera in the dash with offroad mode/rear locker or 4lo, pop it in reverse until the camera comes on then go into drive and it'll be on.
J
JLopez
DC
That fixed it, thank you so much I thought I had been missing something!
