Wilson
Ten cents cheaper
I can tell you that unless Ford says you can run lower then 91 don't do it. I know the Gen1 is a different animal, the owners manual says you can run 87 and the 6.2 would lose about 10hp. 10hp so what you can't feel that loss, but what I noticed is that the truck (bone stock) did not idle smoothly on 87 so after 4 tanks of 87 to see if the truck would learn to like the 87 it did not. Also the gas milage is a little better on 91 or better but it was not enough to make a good case for just that. What sold me on the higher octane was the smoother running engine.
I have owned lots of Turbo cars and what I can say is they just run better on higher octane gas. Do what you want but I would run 91 or better in a Gen2 after all it is considered a performance truck.
Adding a CAI and muffler may not make much of a difference on the Gen2 without a tune. It may even run worse but who knows until someone gives it a shot.
I think someone did post it and I am only saying what I would do. If they say it is good to go on 87 then they can't say anything if something was to go wrong i.e. try to blame you for running the wrong fuel. I have seen that happen in the Subaru Mitsubishi world when someone runs 87 when 91 is required.
