GEN 2 Tune 2017 ford raptor - yes!!
SilentShooter
Siesta Key, FL
Remember all Ford claims are not at the wheels and I would say are overstated on the kits. A custom tune is still normally way better but I would wait till the safe zone is found on the new EB before you run an aftermarket tune.
I would love for ford to offer the ability to turn on and off the tune as far a octane requirement goes so you can run 87 when on a long road trip and 91+ when going to play with the truck
Wilson
South Dakota
just use e-30 cheap octane it's a premium fuel don't know why you guy's aren't ******* unglued to get it where you live.
03'Darin
Harrisburg Pa
ill believe it when i see it.......
They did the track key on the Boss 302. Run the key with the red center and it runs a map with multiple different parameters.
I think the same concept would be perfect for the truck. I think the Track Key was designated as track use only so the Raptor key could be designated as off road use only.
One key for performance and higher octane fuel. Other key for normal use. Would be perfect for me.
SilentShooter
Siesta Key, FL
You won't be seeing a Separate key unless the PCM in the Raptor is designed to be dual capable. The Track key was part of the actual design of the Boss mustang from launch and it actually did not increase the HP. It changed the power band, AF and other settings such as TB response and the like for track use. But back to back dyno's showed no improvement in power.
