Truxxx Leveling Kit for 10 Raptor
FlounderStalker
For normal on-road driving you will not notice any change in the ride with the shock adjustment. it's just that when you hit big bumps the shox will already be somewhat out of their "stock" operating range and thus they will react differently when a large jolt is experienced. the stock setting would allow the shock to effectively dampen the blow within normal ranges where adjusted shox may stiffen up(prematurely?) on less large bumps causing an uncomfortable ride.
but, alas Flounder man...your life story revolves around stiffening up prematurely so I wouldn't worry :naughty: :)
I'm sportin' a little chub already.
FlounderStalker
so I see that the Raptor riffraff has found yet another forum to desecrate.
Lawd hep these peoples here.
:025:
Hey BoBo. What r u doing here? You'll need to check you Z card at the door, but please tell Wiz and Esad we really miss 'em. :Wedgie:
BOJANGLES
<span style="color: red;"><b>Administrator</b></sp
Chihuahuan Desert (EPTX)
:slap:
I toldja man, Bojangles is universally accepted across the Raptor Forum Universe because I's is nice to peoples and I don't talk no jive, ya dig?
I'm like Robin Hood up in this Motha' ....Angels sing, children dance, and wenches coo when I grace my presence.
:boobs:
:Get him!:
:boobs:
kglesq
Droid's Brother
No but.......he probably would make more money doing the leveling kit. However, it's not the first time that i've heard that moving the shock to the middle ring somehow compresses the shock. Doesn't make sense to me.
Actually, that would make sense in a position-sensitive damper like the internal-bypass Fox's on the Raptor. Remember, the beauty of these shocks is that their effective valving changes throughout the stroke, so that they can be compliant early in the stroke, yielding excellent small-bump sensitivity, while firming way up later in the stroke to prevent bottoming.
Moving the snap-ring changes the height of the spring perch, but the spring's force remains the same. This extends the resting eye-to-eye length of the shock further, reducing the sag preset by SVT for the truck, and thus when the suspension is in its 'neutral' position, the piston is higher in its stroke than it was intended to be.
Sag is a critical component of suspension setup, and reducing or eliminating it can cause serious issues with suspension performance.
I'd guess that SVT's engineers spent a LOT of time tuning the suspension in the truck, and from my admittedly limited experience (my truck's on order but I've had a few test-drives) and from what I've read, they did a stellar job. Changing ride-height is one thing, but dialing-out sag is an entirely different story. I'd go with the spacers if you want to pick up the front end.
Just my opinion. . .
