Transmission oil change
RaptorBoy10
RaptorBoy10
Thanks guys.. I hope it doesn't screw up the transmission when I do the oil and filter changed... would really suck, gotta get it ready for Raptoberfest!!!
Houston Raptor
You ever do the transmission oil change? I have a 2010 with 92k and have been wondering if I should do it.
Napp E Roots
Hyper hi-jacked!
Anyways, change your fluid and filter. Manufacturers don't say "oh if you've missed a fluid change, dont worry about it"
SZDZMTR
Sewell, NJ
definetely start with changing the trans fluid. cheapest way to address the problem. Trans shop around us usually would add and additive to fluid for higher mileage vehicles. they would also check if your fluid is burnt. good luck
