TRAIL TURN ASSIST
Littlefx4
My guy…thanks so much!
Littlefx4
never used forscan. maybe ill be getting it and doing some research. crap.
Had a 17 Rap and never used it nor did I know anything about it…til now. I was just as skeptical. After making the first change successfully (eliminating the double honk), it was off to the races. Just be sure to 1) back up the modules “before” you makes changes so that you can always revert back to original settings if need be and 2) double check & triple check the module you’re about to change ensuring you’re changing the right one. Everything else is easy, just follow the prompts. There’s a whole tutorial, w/ videos, explaining how to use Forscan.
Long story short, it’s a piece of cake.
RamseyF
michigan
thx. this time I may have the dealer do it if they know how to by now. because they still have to get the fan noise from the on board gen. fixed. they should be able to. its listed as being available. at least in the info ive seen. why its not there is weird to me.
RamseyF
michigan
ive been doing more reading. it said trail turn was not available with blue cruise. is that the reason MY21 didn't have the trail assist turned on since my truck was prepped for the blue cruise and I got the refund. that was overlooked and now it needs to be turned back on since we cant use blue cruise anyway. could this be an issue to activate now.
NJ2020
Twin Cities
It is unrelated to bluecruise. Trail turn was never activated for 21s or marketed, but the software is there. Who knows why it wasn't activated, maybe it didn't complete testing or had bugs - we will probably never know.
Your dealer will not be able to activate this for you. Forscan is just some independent software (I think Russian?) that allows access to modules to make changes. Not really OK'd by Ford.
NJ2020
Twin Cities
messed up thing is it is in the manual that I have it. kind of a bummer. I probably won't mess with it for now anyway.
not to mention the whole right up on ford authority saying its there.
2021-ford-f-150-raptor-features-trail-turn-assist
there lies the rub.
That article was written as 2022s were getting built. This was the only official quote by Ford on why 2021s didn’t have it:52D9F1D2-9B38-478E-8974-6E7D0455BA20.jpeg
