Frank N
22 psi at 80mph...what could go wrong...
Nah, SVTKid says 22-24 is perfect. Tire compression gives you an extra 6” of travel.22 psi at 80mph...what could go wrong...
I’m well aware of airing down and how tires function. Slow your roll kid, you have no idea what experiences people here have and who you’re talking down to.
When I ran projects on a lot more hardcore truck than a Raptor we kept them around 35, and that was on a 37” tire.
So yes, most will tell you if you’re pinching the tire against the wheel, your pressure is too low.
Run them at 30 and I’d bet this problem goes away, and the truck doesn’t feel nearly as washy in the corners.
Three people have pointed this out, but the OP hasn't really engaged, so ...
The rim is scuffed/bruised. SOMETHING bad happened that no tire in the world is going to like.
C and E are just "ply rating" but not actual plys. Both BFG and Toyo RT use a 3 ply sidewall. Not to say that BFG may or may not have stronger sidewalls but they're both 3 plys. The bubbles can happen to any tire though. I had a customer with a duramax who had his BFG's bubble on a road trip. I think it's more a MFGR defect than a design failure.
From the looks of the damage on the wheel something was hit pretty hard.
