Looking at the pic and the damage on the rim, it looks like there was a significant impact that would have pinched the tire. Toyo and Nitto (same company) are usually pretty stout. However you may have got some from a bad batch.
Lots of people on this forum run Toyo RTs without issues like you experienced, myself included. Not sure if you have a bad batch of tires, but it sure seems like the low PSI and large jolts have something to do with what you are seeing.![]()
So people jump their trucks with 22psi on BFGs?Your truck is a mall crawler like most people that run Toyos
The PSI is a non-issue. If anything it gives the tire more flexibility to absorb the impact. Also, load range E has more plys than load range C, so it should be more durable and stout on the sidewall.
Just because he has a mark on the tire doesn’t mean it should have bubbled like that. So unless he hit something going stupid fast or hit something obnoxious, that’s how your tires are suppose to look after going off-road.
Flex to absorb the impact... that’s what suspension is for.
C and E are just "ply rating" but not actual plys. Both BFG and Toyo RT use a 3 ply sidewall. Not to say that BFG may or may not have stronger sidewalls but they're both 3 plys. The bubbles can happen to any tire though. I had a customer with a duramax who had his BFG's bubble on a road trip. I think it's more a MFGR defect than a design failure.
From the looks of the damage on the wheel something was hit pretty hard.
I’m well aware of airing down and how tires function. Slow your roll kid, you have no idea what experiences people here have and who you’re talking down to.The tire has to be able to flex and absorb the energy as it makes contact. If it doesn’t have any give to it, then the energy of the impact will cause it to break/deform regardless of how many plys that you have. That’s why lower PSI is better while off-road. With that said, there does come a point where too low of a PSI is indeed too low. But 24 PSI is not too low for running fire roads.
