"Total" Transmission fluid change without Flush
Ruger
Northern Nevada
There is a definite procedure. Chris@freedommotorsports helped me with it. Bottom line is that you must check the final fluid level with the engine/trans at operating temperature, and you WILL burn your hand doing so due to the very close proximity between the exhaust and the dipstick.
dkfc13
HPA Systems LLC.
SE Michigan
The leak is not a slow leak. One day everything is fine, the next there is a puddle on the ground. More than likely you wont notice an issue until you park on a hill.
You dont park on a hill so who cares? Well if fluid can get out, dust and dirt can get in. Hill or no hill, if you are changing the fluid in a 2010 it is a good idea to upgrade the bulk head connector if you havent already done so.
You wont leak out all your fluid, but it will be a notiable amount.
Staff online
96,364
60,273
NTXRaptor
