Conejoracer
I know this thread is a bit old, and you probably are not running this set-up any longer, but I have some questions. With the rear blocks out, did the Fox shocks have enough compression to collapse fully? The 2wd F150's use the same axle, shock mounts, and a similar bump stop arrangement. Without the block, the 2WD uses the axle itself for the bumpstop contact point. If the Fox collapses enough, I want to run that set up for a while myself.
