A lot of questions about the Whipple programmer.
The .apl file you receive and drop onto the SD card will change the Tomahawk's firmware and allow it to unzip and recognize the .bin file you also dropped on the SD card.
Here are some shots to answer some questions:
Initial Menu:
Capture will build a spreadsheet from from the .csv data for an undetermined amount of time, pretty slick.
I talked with Whipple and there is NO provision to go back to stock. In fact the coding embeds into a portion of the ECU that not even your local dealership can write over. For the most part it actually looks completely stock except if the technician digs deep inside and it will state AFTERMARKET EMISSIONS. Furthermore, the tune actually has a Ford part number and it was designed by technicians from Ford. I am not saying they will cover a catastrophic event, but they might.
Initial Menu:
