Tire Pressure
GTC-NOVA
Air up to 40 to 41 psi. and drive for five to ten minutes.
44 psi. is the recommended tire pressure.
Not that I drive with that much psi. I do 40 in front and 38 in rear. But to turn off the light you have to go past 40 psi.
If you get a Tuner you can set the psi lower before warning light pops on
Not sure why PSI recommended is 44, when I picked it up at dealership with 36 and never increased it...only now to 38 and indicator is still on.
MTF
Celebration, Florida
The Raptor weights 6,000 Lbs. the stock tires are rated for 3,200 and change per at 50 psi. I believe.
I'm not looking it up now.
But the less air the less pounds it can safely handle with out breaking the bead or just self destructing.
So if you have an Oh crap moment and your too low on air your going to lose a tire.
Plenty of guys air down while off-roading and have the tires pop off.
Wilson
South Dakota
It's 44psi I run 44 with duratracs works good In snow mud and what not. That's 44psi cold means check them in the morning before you drive it.
