Tire Pressure
6.2
Banned
Canada
It's ok, he's still got me, the Canadian. He don't need you texans!
GTC-NOVA
That's interesting! As delivered, my tires had only 35 psi and I got a low pressure warning in less than a week.
How did you deal with the Low Pressure warning indicator? Mine popped up as I was driving in cold (15 degrees). When checked the tires all are OK at 36 PSI.
Appreciate some feedback.
GTC
MTF
Celebration, Florida
Air up to 40 to 41 psi. and drive for five to ten minutes.
44 psi. is the recommended tire pressure.
Not that I drive with that much psi. I do 40 in front and 38 in rear. But to turn off the light you have to go past 40 psi.
If you get a Tuner you can set the psi lower before warning light pops on
Huck
Chicago Sw Burbs
44 is the recommended cold pressure.
MTF
Yes, cold tire not cold temp outside.
As you drive the tire will heat up even when it's cold outside.
