Throttle body spacer
Wrong Way
I`d try it if it was free, but I would not buy one. But if you want one FTW and buy it :)
R@pt0r
So Ford goes to great lengths to promote turbulence in the intake track. The 1999-2004 PI heads have a quench pad in the head, the 99-01 heads are supposed to produce an air tumble effect (hence tumbleport heads), and the 2005-2010 3v heads have a butterfly valve in the intake tract. That being said, if the spacer induces turbulance, it would be long gone once the air travels through the intake plenum and into the runners. Besides fuel doesn't get injected until right before the intake valve. (So make my plastic intake as smooth as glass.) The spacer is pure snake oil.
Road Kill
Just installed a Volant Vortice TB spacer on my 2011... mistake. Made sense on my LS (GM convert) with the TB in line with the intake manifold. It cleaned up the air flow and dissipated some of the parasitic heat. With our trucks our plenum is already a composite (found this out after removing the ugly air box) and it has veins to direct air flow.
Well it only cost me $35 and I did it at the same time with a Volant intake (which is another story).
