Throttle body spacer
Temple
Utility Muffin Research Kitchen
Just curious if anyone is running one of theses and what the pros and cons are?
2010-2011 Ford Raptor 6.2L Throttle Body Spacer
Dave
Snake oil in my opinion. Put one on my F250 V10 and took it off a week later. Couldn't stand the whistling sound and it did nothing for performance. Others may have had different results though.
BIRDMAN
Birdministrator
Boston
i wonder what the real story behind the dyno chart is? they claim +13 HP and TQ so...??
Hockster
My 45ft Bluewater Party
Winchester, Va
The idea behind these devices is they create turbulence and, turbulent air does not allow the fuel to pool around the ports. One reason when you polish heads and intake you need to make sure there is still enough turbulence to remove the fuel from the corners on the system. So, with these new plastic intakes being so smooth they will tell you that you need this vortex these things create to pull all the fuel so the engine can use it all giving you more HP and TQ......
But the heads are not polished so you have enough to stop the fuel from pooling.
One side effect of polishing the heads and intake is you will lose TQ more than HP.. But, with this 6 speed and the new 8 speeds the TQ is available so fast its not a big deal...
