This truck is amazing
S
speed77
Chicago
Sweet ride. I just keep looking at your pics drooling.
I have the same one on order. Is it a 2021 or 2022. It might say somewhere but I didn't see it. I have a few questions if it's a 2022.
I did the decal Delete but I think I like them on the white truck. Do you have the "R" button on the steering wheel ? if so what does it do ?
It’s a 21. No R button. I find I’m not changing modes as much as I do in other vehicles. I might use Baja mode exhaust more than I would admit to my neighbors . Cold start on normal is pretty awesome.
If I was ordering a 22 I’d get the same spec including recaros. Makes the truck special on the inside.
The decal in person is a bit more than what I was expecting. In photos the map blends in more but on a white truck you can really see it. If I was going to take off the decals I’d add the small gn 03 decal that the 35s have only. Think that’s perfect imo.
nin9r
Wisconsin
The R button is for My Mode. You can have a preset so you don't have to reset exhaust, damper, steering and drive mode each time you start the vehicle. Pick each setting in the 4 you like, press and hold. Since the truck defaults back to normal each cycle of the ignition, you press twice to select and confirm you want to go to your 'mode'. MY22 feature.
Tm2525ai
Pennsylvania
It doesn't save your own custom default without having to select?
Hmm, that's literally the first thing I would be looking to hack...
Azholley
17 AG, 21 IS, R pending
Peoria, Arizona
You sure? My gen two mode and steering wheel preference stays after the truck is turned off and on
Badgertits
Ma
Wtf that’s weird. I just tested it this morning and it stays? Maybe cause I have a tune on mine? Idk.
Weird I have tune on 2020….tune or not it seems to hold steering wheel feel setting & will stay in 4a (or 4H/4L obvi) if that’s what I had it on (vs defaulting to 2h) BUT it won’t hold the drive mode, if I shut off in 4a weather mode + sport steering when I turn back on will be in 4a but in normal drive mode however the steering feel will stay sport. Weird
