Things to check after taking delivery
Tampaukfan
Florida
Is all the yellow masking tape in the suspension area supposed to be removed by the dealer as part of the delivery inspection? I had a bunch of yellow and black masking tape hanging loose from various bits. There's also some white masking tape that seems to be doing nothing that I didn't pull off.
There was some loose plastic wrapped around the bottom spring perch also that I just removed.
This is normal for Ford.. check the engine compartment for rubber bands, should find at least one.
Owned 2 Gen 2's and one gen 3, all had random bits of tape here and there and lots of rubber bands.
Orlando, FL
Took delivery of my 2022 801A on Friday and put it up on the 4 post lift to do a full inspection today.
August 2022 build date.
Found:
clear tape on passenger front shock
misc yellow and black masking tape scattered about
vent hose not clipped at fuel fill neck
Everything else seemed ok but I did not know about this thread when I did my inspection. I'll check the fuses and hoses tomorrow.
Truck has the signature exhaust muffler rattle. I thought I had found the source being the exhaust actuators have metal mesh that is loosely attached to them but I fired the truck up and put my hand there and the noise didn't change. It's coming from the muffler somewhere but it's not the protective mesh on the actuators.
All in all, it's easily the best riding and most comfortable truck I've personally ever owned and it shows a lot of potential once tuning is released
Littlefx4
Found:
Pics or it didn’t happen.
Jlchavezz1
South Texas
Picked mine up two weeks ago. Found yellow and black tape in multiple locations (no big deal) and clear tape on the front two shocks. Also noticed rust on rear axle. Not sure but I think this may have happened in storage/ shipment and probably normal.
