Texas Raptor Run April 18-21 2013
FarFromStock
Chuluota, Florida
I'm sure he will too, but I was just trying to get a head start on buying the necessary gear.
From last year's TRR thread http://www.fordraptorforum.com/f113/texas-raptor-run-april-13-15-info-thread-11381/, I got this list of required/suggested items:
Required Gear
1. A DOT approved helmet for every one in your Raptor.
2. Fire Extinguisher and a way to mount it.
3. First Aid Kit
4. Tow Strap
Suggested Gear
1. Extra Spare Tire
1.1 Tire Plug Kit
2. Spare fluids
3. Shovel
4. Lowrance GPS
5. VHF Radio
6. Misc. Spare nuts and bolts
7. Fan Belt
8. A way to secure everything. (This one is important)
whtrapta
Ostrich Wrangler
Bolivar/Springfield, MO
Required Gear
3. First Aid Kit
4. Tow Strap
Suggested Gear
1. Extra Spare Tire
1.1 Tire Plug Kit
2. Spare fluids
3. Shovel
4. Lowrance GPS
5. VHF Radio
7. Fan Belt
I can vouch for the extra spare! this time I will have my play tires with me though.
All The Way
Lockport, NY
Yea I need to gear up. Things I still need..
Fire Extinguisher
First Aid Kit
Tire Plug Kit
Lowrance GPS
Spare nuts and bolts... Do the loose ones in my head count?
Fan Belt
Wilson
South Dakota
ya a check list of every thing you had or wish you had I see a sticky comming or at least a post about every thing you should have for trr.
treypal
Lord of the Raptors
Riviera TX
Expect a major update on the event by Halloween. Date is set April 18-21. I will have a bunch of information by the end of the month!
PARKER
Houston
So looking forward to this! I'm already going to request time off.
Yukon Joe
Trafford, PA
Fire Extinguisher
First Aid Kit
Tire Plug Kit
Lowrance GPS
Fan Belt
I would DEFINITELY add axillary lighting to your list if you plan on running at night. The stock heads SUCK! And unexpecting wild life will be roaming the hills of the ranch. :sunot:
Additionally, if you are thinking this far in advance about what you need, I would recommend a good way to mount your Fire Extinguisher. I had mine resting in the cubby hole below the rear seat last year. It work with no issues. It didn't go anywhere. BUT accessibility wasn't good. Check out the way I mounted it using the WSI FE mount. He also offers a way to mount it to a chase rack if you plan on getting one.
http://www.fordraptorforum.com/f190/fire-extinguisher-interior-mount-15839/index2.html#post285034
Members online
96,401
60,331
JaytheGreat90
