Taking Orders on Toyota, Tundra (2022-On) Kits
Baja Designs
From fog lights to light bars, light up the night wherever your next adventures take you. Our scientists of lighting have crafted light solutions from mild to wild to make sure every Tundra enthusiast is able to torch the road ahead of them.
From the stock Tundra to the TRD Pro, our LED Light Kits for the Toyota Tundra are designed to mount cleanly to your vehicle. The all-new third-generation Toyota Tundra represents a bold new approach in both styling and performance. Make your Tundra stand out from the rest with high-power lighting kits from Baja Designs. Do not let the night hold you back on your next adventure and get your Tundra Kits today!
See Post Below for more kit info
Baja Designs
Baja Designs
2022 Toyota Tundra S2 Sport OEM Fog Light Replacement Kit | SKU:448080 | Link: Toyota S2 Sport OEM Fog Light Replacement Kit - Toyota 2022 Tundra - Baja Designs - Off-Road LED & Laser Lights | Automotive, Jeep, Truck, UTV, ADV, Dirtbike
The S2 Sport Fog Light Replacement Kits give you the ability to replace your factory lighting making for quick and easy installation with no difficult wiring, trimming, or splicing.
bOrCrLCqOwSNLDg0z4um33BJZ0WIRhaWGumHX_mGjvgysEOkZE.png 9EN2qqS9ak7S-bafpkMtxU7ytTW2w1A5ewfaCAnXQwaTMOdE8M.png
S2 Sport setup includes the following:
  • (4) S2 Sport, Wide Cornering
  • (2) Mounting Brackets
  • (2) Adapter Harness
  • All necessary hardware
Specifications (Per Light):
  • Lumens: 1,130
  • Wattage/Amps: 12W / 0.9A
2022 Toyota Tundra, 20” S8 Behind Bumper Kits| SKU: 448076 | Link: Toyota S8 20 Inch Behind the Bumper Light Kit - Toyota 2022 Tundra - Baja Designs - Off-Road LED & Laser Lights | Automotive, Jeep, Truck, UTV, ADV, Dirtbike
The new Toyota Tundra 20” S8 Behind Bumper Kit gives you off-road performance while maintaining a seamless appearance. This kit utilizes our 20” S8 light bar with no major modifications to the vehicle.
K1ngKPFrIij16N__ioyx9vLaGui5GUwiJFCGjDDNw8oTVDmL9g.jpg07zUnFe-P9HPJn9xcAOxDFL4xHIc3B2lrxDRfSlFgnSColnWtY.png
20” S8 Clear Setup includes the following:
• (1) 20” S8 Clear Driving/Combo Light Bar
• (1) Wiring Harness
• (1) S8, Backlit Add-On
• Lumens: 12,700
• Wattage/Amps: 120W / 8.0A
2022 Toyota Tundra TRD PRO OEM, 20” S8 OEM Replacement Kits | SKU: 448078 | Link: Toyota S8 20 Inch TRD Pro OEM Grille Light Kit - Toyota 2022 Tundra - Baja Designs - Off-Road LED & Laser Lights | Automotive, Jeep, Truck, UTV, ADV, Dirtbike
The 20” S8 OEM Replacement Kit gives you the ability to replace the preexisting light that comes with your 2022 Toyota Tundra TRD Grille. This kit allows you to maintain the low profile appearance while maximizing the performance with our 20” S8 light bar.
-8lhkfSXTOPYuBloex1veg_KUjPTA9EWARv96ViYdpfr43O1cg.pngLYLosHa5x3nvnABAFrlcdLD4NeSTnvLbY5jz6Eq8FtkQr2Tf-I.png
  • Lumens: 12,700
2022 Toyota Tundra, A-Pillar Kits | SKU: 448072 | Link:
Toyota XL Sport A-Pillar Kit - Toyota 2022 Tundra - Baja Designs - Off-Road LED & Laser Lights | Automotive, Jeep, Truck, UTV, ADV, Dirtbike
Baja Designs Toyota Tundra A-Pillar Kits give you the ability to continue your adventures late into the night! These kits give you the option to utilize our XL Sport, XL Pro, or XL80. With the provided A-Pillar brackets, installation is simple and Baja Designs brackets are designed so there is no vibration, even when running down wash-board roads.
XL Sport setup includes the following:
  • (2) XL Sport, Driving/Combo
  • (2) A-Pillar Mounting Brackets
  • (2) XL Clear Spot Lens
  • (2) XL Clear Wide Cornering Lens
  • Lumens: 3,150
  • Wattage/Amps: 26W / 2.0A
XL Pro setup includes the following:
  • (2) XL Pro, Driving/Combo
  • Lumens: 4,600
  • Wattage/Amps: 40W / 2.9A
XL80 setup includes the following:
  • (2) XL80, Driving/Combo
  • Lumens: 9,500
  • Wattage/Amps: 80W / 5.5A
2022 Toyota Tundra, A-Pillar Kits LP4 | SKU: 448075 | Link:
Baja Designs Toyota Tundra A-Pillar Kits give you the ability to continue your adventures late into the night! These kits give you the option to utilize our LP4. With the provided A-Pillar brackets, installation is simple and Baja Designs brackets are designed so there is no vibration, even when running down wash-board roads.
LP4 setup includes the following:
  • (2) LP4, Driving/Combo
  • (2) Clear Spot Lens
  • (1) IPT Reflector Cover Kit
  • Lumens: 7,050
  • Wattage/Amps: 60W / 6.5A
  • IPT Lumens: 1,700
  • Wattage/Amps: 15W / 1.0A
  • Backlight Wattage/Amps: 4.8W / 0.35A
2022 Toyota Tundra, S2 Sport Reverse Kit| SKU: 448082 | Link:
Looking to get dust lights or reverse lights for your 2022 Toyota Tundra? Baja Designs has you covered with our reverse light kit. This kit comes with lights, brackets and wiring harness making it a breeze to get rear-facing light setup on your truck!
  • (2) S2 Sport, Wide Cornering
  • (1) On/Off Wiring Harness
  • (1) 10’ Extension Harness
  • (1) 55” Wiring Splitter
  • Lumens: 1,130
Donovan
DC
Bro this truck looks like a knock off IRON HIDE
I'm crying at work laughing lol.
