Sync Sucks
FDHog
NJ Shore
About a month ago my Sync system has gotten a mind of it's own.
First the screen went blank. Restarted and it was fine. since then it has booted up without audio controls, and then without Nav. This has happened 3 times and each time I do a reset (vol and FF buttons) and it works fine.
Can't bring it to dealer cause I can't replicate it at will. Weird.
CoronaRaptor
CANADA
Does that happen when your phone is plugged in? Back when my gen 1 was new and I had a blackberry, weird shit use to happen, the volume would get stuck loud and the nav would freeze. Somehow it fixed itself after I started using an iphone, lol.
dgr810
Agreed. I just posted about this down below. Truck Goes in on Weds. I just have a dead screen - no radio - Bluetooth- CarPlay - back up cam - nothing. No sound either. Silent car rides are awesome. It’s always been glitchy. This is the first time it decided it was going to off itself.
FDHog
FDHog
NJ Shore
Does it without iPhone connected. Guess I'll just wait till it craps out. Seems like a software issue. Like it doesn't boot up properly and needs a kick in the ass.
Too much electronics in these new trucks. If I keep it past 3 yrs there's an extended warranty in my future.
pat247
Oklahoma
A good rule of thumb when starting a newer car or truck, cycle the key to on(not start), wait 2 to 5 seconds (your choice) then start. Will save you many seconds down the road. As with all computers sometimes a driver will not load correctly because of where it is in the startup sequence and sometimes the file just gets corrupted. Usually the SYNC maintenance thing that happens every so often will fix these kinds of problems.
bobn
"The Last Best Place"
The good ol' black screen of death.
Have to be careful with warranty stuff. As if you report an issue and the dealer can't replicate it, you are now charged for labor. Guess this policy changed in the past couple of years, but I just recently found out about it.
FastEddie
Had similar sync issues with my gen 1. Took it into dealer several times and they replaced some modules. Was getting close to where I was going to being able to lemon law the truck, but they ultimately had a ford engineer come out and he fixed it.
