GEN 2 SYNC radio very slow to respond to touch
Cedar Park, TX
Hi all. I have a 2018 that has started to respond extremely slow on the radio screen. I have noticed that it seems to take forever for the message to come up notifying that data is happening over SYNC Connect. But once that message occurs, the radio seems much better.
On and off, I see the "No GPS" on the map as well, which then makes it become useless. My Raptor just went out of warranty, so I'm hoping this is not expensive.
Tried so far:
-Master Reset
-disconnect battery for 30 minutes then do Master reset
-hard restart of radi with the power and right button
None have fixed this.
Donovan
DC
How many miles on vehicle, not that it matters.. Mine acts up onces a month. I am at 72k.
91Eunos
Hill country, Tejas
Same here... including an update to Sync
The reboot and update helped a bit, but still getting the slow screen response, and bluetooth is all but impossible. Stays connected for a couple seconds then disconnects. I have to plug in the phone and use car play to make hands-free calls.
Becoming tiresome
SetInCalifornia
Cedar Park, TX
I'm only at 25k miles now. The SYNC system is infuriating to use in this state. Dealer says they will have an electrician look at it in JULY because they are that backed up with service calls. I'm concerned this is going to get expensive fast if its not a common problem.
I saw on a couple other threads that the APM (whatever that is) may be the reason and need replacing. No idea what that involves.
FordTechOne
Detroit
Have you updated the software? That may resolve your issues.
guyzilla
I too have an '18 and did I software update via flash drive and tried wifi update search as well yesterday. I'm still on sync 3.0. Is this the last update for the 2018? Thanks.
FordTechOne
Detroit
jond
OK
I have a 2018 had same issues. Dealer replaced the APIM module under extended warranty. Seems to be a known issue.
